Vibration and Locking
Discussion in 'The Garage' started by grindkings, Jan 2, 2005.
  1. grindkings
    grindkings 1/2 ton status
    Dec 24, 2004
    127
    Marshall, Missouri
    I just replaced the front u-joint on the axle. Went for a test drive and still had lots of vibration in the front end. Then as i began braking, one of the rear tires locked up, then unlock. Not sure what this is caused by, maybe bad diff or brakes or anything. need so help boys.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    did you replace the u-joint in the axle shaft or the front driveshaft??
  3. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    The one that connects to the front diff.
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    The vibration could be alot of things in the front end. Was it there before the u-joint replacement?
    As for the rear wheel locking up, it most likely is a leaking wheel cylinder or if have a 14 bolt, it could be a bad hub/axle seal.
  5. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    it was doing it befor i replaced the u-joint, thats why i replaced it.
  6. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    was the truck sitting for a while cause that can cause some rust build up on the brake drums and make it lock up it usaully goes away with in a couple miles
  7. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    No it happend when i went mudding.
  8. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    could there be mud throwing things of balance
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Do you still have the rear 10b?? if so then just take the drum off and I would bet there is mud caked in the drum just clean it out with some brake clean and all should be fixed.
    As for the vibration is it coming from the front??
  10. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    It feels like the front. But when i drove it, i felt a hard bang and then the tires locked up when i started braking. then unlock
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    If the vibration is in the front it could be a number of things but did the vibration start after you went mudding??
  12. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    correct after i went. Thats why i figured i blew a u-joint.
  13. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    are you sure it is out of 4wd?? maybe the shaft is out of balance and the vibration is in the shaft and it is still in 4wd.
  14. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    yea, I've been driving it for almost two days(well not actually driving because but i had to drive it about 12 miles home.)
  15. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    well then maybe you have a wheel bearing going south, just check everyhting for looseness or excessive wear.
  16. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    the hole rear drvier side drum was busted. I could just pull the outside of it off and the internals where all rusted. How do i reapair this brake?
