vibration and noise while at idle
Discussion in 'The Garage' started by stoneman667, Jul 22, 2004.
  1. stoneman667
    stoneman667 Newbie
    Jul 20, 2004
    3
    NJ
    When I drive my 88 k5 i notice a vibration coming for under the truck, it sounds like its coming from the trans, but it only does this while idleing and not under acceleration or while cruzing. any thoughts? /forums/images/graemlins/dunno.gif
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    what about while decellerating? check the trans mount 1st. the bolts of the crossmember. also check the heat shield if there is one. My 79 had a heat shield that when i swapped transfer cases the speedo would tick at idel but not anytime else drove me nuts til i cut the shield.
  3. stoneman667
    stoneman667 Newbie
    Jul 20, 2004
    3
    NJ
    no their is no vibration while decelerating, just while parked at idel or stopped at a light around town
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Is your A/C on ? Mine vibrates a bit at idle , mostly in gear . I sat and watched my comprerssor vibrate on the brackets , runs fine , so I said forget it , run it until it dies , get another .
    Its is something to check into , it will shake every loose thing so it sounds like its elsewhere . It won't hurt to look , thats free /forums/images/graemlins/k5.gif
  5. stoneman667
    stoneman667 Newbie
    Jul 20, 2004
    3
    NJ
    i normally dont run the ac and i have tracked the vibration to under the truck any other thoughts?
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    high pitch or low, metal to metal?
  7. stoneman667
    stoneman667 Newbie
    Jul 20, 2004
    3
    NJ
    its a low pitch, and not metal to metal
