vibration and shaking, what could it be?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smad, Mar 24, 2002.
  1. smad
    smad Registered Member
    Mar 17, 2002
    8
    My truck shakes real bad and it seems to be getting worse, mostly it shakes whewn I am going between 10 and 45 after that it seem slike it gets a little better, is it a tranny mount, axle, driveshaft? What could casue this, I recently replaced my motor and my transfer case but it didn't shake this bad.
  2. JohnnyFresno
    JohnnyFresno 1/2 ton status
    Mar 24, 2002
    194
    Clovis, CA
    sounds like your timing is off to me. I am having the same problem.
  3. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    Death Wobble...been discussed in great detail here lately. Do a search on "death wobble" you will get all the info you need
    Chris
  4. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    If you didn't put your drive shaft back in the way it came out, it'll put it off balance also. That shaft is balanced. Always mark it when taking it off to make sure it's bolted up the same.
