Vibration at different Speeds
Discussion in 'The Garage' started by tarheel, Apr 1, 2004.
  1. tarheel
    tarheel Registered Member
    Apr 11, 2003
    65
    GA
    i've got a '73 k5 w/ a 4" skyjacker lift and 33's. not much else has been done to it. anyway... i realize that the truck is 30+ years old, but i'm getting some bad vibrations (it's actually more like hopping) /forums/images/graemlins/ooo.gif at around 20mph and then again at 55 mph. anybody know where the problem might be? /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif
    tia,
    matt
  2. tucsonkfive
    tucsonkfive 1/2 ton status
    Jun 9, 2002
    133
    Tucson, AZ
    Possibly a broken belt on a tire? Jack it up and spin the tires. Should be able to tell.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Yeah, sounds like a tire problem to me, maybe out of balance, may have lost a weight or something, or as previously mentioned, a broken belt / tire seperating.
  4. tarheel
    Apr 11, 2003
    65
    GA
    thanks for the info!! /forums/images/graemlins/thumb.gif
    dumb question... but if i spin it and there is a problem, how will i tell? /forums/images/graemlins/thinking.gif
  5. 4xcrazy
    Oct 31, 2003
    9,471
    5
    You will see on the tread area of the tire if there is any seperation or bulging, it's usually pretty obvious.
    But as mentioned before, it could just be something as simple as a wheel weight had fallen off, check to see if you are missing any weights, usually the sign is a clean area where the weight used to be.
