Vibration cause??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mike87, Jan 3, 2002.
  1. Mike87
    Mike87 Registered Member
    Feb 18, 2000
    20
    San Jose, CA, USA
    Can the U-joints in the front axle cause a vibration if they are bad? I have a vibration that comes on about 65-70mph and continues to as fast as I can go. I have replaced just about everything in the driveline with the exception of the front axle U-joints. The rear drive angles (output of T/C and rear pinion) are almost dead equal. Can't think of what else to check.
    Any ideas?
    Thanks,
    Mike
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    While in 2-wheel drive, your front axle isn't spinning. That is, unless you have a bad hub locking on the shaft(s). With that in mind, the u-joints on the front axle don't even come into play. If the front driveshaft is spinning while in 2H (it will spin a little, not much), or you can't manually turn the driveshaft while the truck is in 2H and parked, you have another issue entirely, one which I'll let those more knowlegdeable field...
    Check your wheel bearings CLOSELY. I had a similar problem with vibration in the same speed range...turned out to be a loose bearing on the drivers side.
    Good luck!
    Haze gray and underway...<font color=blue>or blue, in my case.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/album/26246038MbQsYWKcbo>U.S.S. Nimitz II</a><P ID="edit"><FONT class="small">Edited by Burbinator on 01/03/02 01:26 PM.</FONT></P>
  3. kilroy
    kilroy Registered Member
    Nov 25, 2001
    85
    Alaska, Anchorage area
    yes they can, but had you done anything else around the time this started( put on a lift, offroading, changed axles,) also it could be a slight wheel imbalance (look for a clean spot on rims where it looks like a weight was thrown off.).
  4. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    Let's clarify...a front u-joint CAN cause vibration ONLY if operating in 4 WHEEL DRIVE.
  5. Mike87
    Feb 18, 2000
    20
    San Jose, CA, USA
    Thanks for the info. I think I have bad ball joints, or something else in the steering, so I guess that is the next thing that will get rebuilt. I will let you know what I find.
    Thanks again,
    Mike
