vibration dampner question
Discussion in 'The Garage' started by K5dreamer, Apr 8, 2007.
  1. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    hey all, ive been reading that the 6.2L and 6.5L diesels have a known problem with the harmonic balancer (vibration dampner) coming apart and causing crankshaft failure. Is this a serious enough problem that it would be worth getting an aftermarket unit as a preventative measure? or should i just keep an eye on it and wait for visible signs of failure before replacing it?
  2. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    if its coming apart then it is probably not something you can monitor without pulling it off and checking it for cracks, maybe even having someone do a dye penetrant inspection. I would say that if you are truely worried about this buy a new one and replace it. If there is a window of failure, say 40-50k miles then replace it that often. I am not personally familiar with this problem but I sure would rather replace a balancer every so often, rather than a whole crank.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Some 6.5TD info is here:
    http://www.dieselplace.com/forum/showthread.php?t=140023
    From my understanding the balance on the 6.2L is the same, so it may just be a matter of updating the accessory drive to serpentine.
    I am researching these vibration issues more lately since having smashed the clutch in mine 2 weeks ago.:crazy:
