vibration from drivetrain
Discussion in 'The Garage' started by gator688, Feb 20, 2007.
  1. gator688
    gator688 Registered Member
    Jan 29, 2007
    27
    Gordon, Al
    Okay so I talked to the guy who installed my lift today and he said that the vibration that I get from around 10 mph to 45 mph could be caused by the driveshaft needing to be lengthened. Anyone with 6" lift know anything about this or is the guy just trying to get me to give one of his buddies that builds driveshafts somework. I personnely feel that he just didnt get the angles right but I am new to this and only know what I have learned on the TV shows everyone loves to put down. Not to many people have lifted trucks around me except for those pretty street trucks that never even see a dirt road and they dont count.
    Help, Im new, Im new, I dont know what to do!!!!!!!!
  2. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    I no they are a little expencive but.....A CV shaft. Have one made they work great
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    If you have a slip yoke t-case (208 or 241) he could be right.
  4. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    from the pic it is an 80's Blazer? would be a slip yolk NP208 tcase. I had to drop the tcase a few inches and add a 6deg on the rear 10b to get rid of the vibration. length is not causing the Vib but she might need to be longer just so she is not sticking out to far on the tail shaft. Also with 6" you will have to add a spacer or lengthen the front drive line and clearance it as well so she will not bind.
    The vib should be pinion angle. Do a search for more info.
  5. 87'k5boggin
    87'k5boggin Registered Member
    Dec 9, 2006
    76
    pascagoula,mississippi
    i have the same vibe on my 87' with a 6'' lift and 36's, i have about a 6 degree shim on the axle and it only gets a vibe at 40-45, then past that its smooth.
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    The angle is probably off, but the driveshaft probably needs to be lengthed also.
    Once you get the angles where they need to be, you may find that your Dshaft will be maxed out at ride height.
    Pics of your angles would help.
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I put a 4" lift in mine and at first lowered the pinion angle to get rid of vibration and get proper pinion angle. Then due to the shaft being a bit too short for comfort on full suspension drop I bought an HAD cv shaft and angled the pinion up to the proper angle to suit. Now I have no vibration at all from crawl up to over 100 mph.
  8. bbck5on37s
    Jan 3, 2007
    543
    Denver Colorado
    I had a 6 degree shim and still had the vibe. I had a local shop build my cv. It fixed the problem
  9. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I just got my CV shaft in from HAD. It is purdy.
    Ok, back to the topic.
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    They sure are and don't you just love getting parcels that you need a tool kit to open!!!:D
