Vibration Help
Discussion in 'The Garage' started by Mule man, Aug 7, 2005.
  1. Mule man
    Mule man Registered Member
    Feb 14, 2005
    28
    Arkansas
    I have a '79 K-20 with the 465/205 combination. I have dealt with a slight vibration for 2 years. It developed and is not the result of a crash. I can jack the rear off the ground and the drivers side rear wheel hops up and down. I have gone from the 2 piece driveshaft to a 1 piece that was balanced and has new U joints. I installed a 2" lift a few years ago that has the blocks for the back. They are tapered to give a better driveline angle. I have dropped the tranny/transfer case so that the transfer case is pointing straight at the rear pinion. I have tried new tires and rims and there was no change. The wheel hop is only on the drivers side. Could a bent axle tube cause a speed specific virbration? Sorry for the long post but I am close to the end of my rope. Any help, opinion or advice will be greatly appreciated. I know this is not a K5 but this seems to be the forum with the greatest number of people who actually know what they are talking about.
  2. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    if you got a full floater rear end.you can tell if you have the 8 bolts in the center of your rim . your rear hub bearings are shot and need to be replaced. is there alot of gear oil leaking from that same tire that hops?
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Is any oil leaking from the shock on that side?
  4. Mule man
    Feb 14, 2005
    28
    Arkansas
    Thanks for the replies. There is no oil leaking from the shock. I have replaced the wheel bearing and seal. The old bearing was still tight. It's a 14 bolt full floater axle. Vibration begins about 53 and becomes less obvious about 65. I have swapped different tires and rims. No change. I have BF Goodrich 265-75R16's on the truck. Nothing radical. It seems to be worse when pulling a load (6,000-8,000 lbs.) Thanks again.
