Vibration in my '03 2500 suburban above 60 MPH
Discussion in 'The Garage' started by The Butcher, Nov 24, 2006.
  1. The Butcher
    The Butcher 1/2 ton status Premium Member
    May 17, 2005
    420
    39
    Texas. In a van, down by the river!
    For some reason my 'burb has developed a shake in the seats above 60 MPH. The steering wheel stays true, but the seats (and the rest of the back) get a noticeable shimmy when I get above 60 MPH. It is more noticeable some times than others. It is almost as if it will catch an irregularity in the road and then amplify the shimmy.
    I have a 6" RCD lift kit, and 35" Nitto Terra Grapplers. When I put the kit on I took the driveshaft to a local shop and had them lengthen the shaft (can't recall how much, but my mechanic measured it and told me at the time how much longer it needed to be). This is a 2003 2500 suburban 4x4.
    I have had the tires rotated and balanced twice, and that did not solve the problem. I got underneath and tried to wiggle the rear driveshaft, but it is snug as can be so i am guessing it isn't slop in the u-joints. The kit has about 40,000 miles on it, and the truck has about 46,000. I would guess the vibration started about 5,000 miles ago. Maybe a little longer. Anyone know how to make this annoying shake stop? Thanks.
  2. The Butcher
    May 17, 2005
    420
    39
    Anyone have an idea what it might be? It's real annoying, and I'd like to figure out how to stop it! Thanks.
  3. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    Did ya check your frontend?
  4. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    sounds like a driveshaft shake to me, id check to see if its thrown any weights...
  5. The Butcher
    May 17, 2005
    420
    39
    From what I could see, the shaft still has the weight attached. I didn't notice any place where it looked like a weight might have come off.
    If the front end was out of alignment, i would think the steering wheel would shake. It doesn't at all.
  6. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    I was thinking loose tierod end....
  7. The Butcher
    May 17, 2005
    420
    39
    I would still think I might get some feedback in the steering wheel if it was a front end issue. There isn't even the slightest vibration there though. Kind of frustrating. Thanks for the input though!
  8. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Does it onpy happen in gear? Ie if you were going down the road at 60 and put it in neutral does it still happen?
