vibration in rear of 89 blazer *DELETED*
Discussion in 'The Garage' started by brando, Jan 10, 2004.
  1. brando
    brando Registered Member
    Jan 10, 2004
    10
    Gering Nebraska
    Post deleted by brando
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Re: vibration in rear of 89 blazer
    have you checked the rear pinion bearing for play? The only other thing I can think of is your pinion angle. If you have a CV shaft in there, I would either get your spring perches moved, or add shims to make you pinion straight in line with the driveshaft. Just my 2 cents. /forums/images/graemlins/thumb.gif
    Rick
    Oh yeah, welcome to CK5! You'll find that this place has more info on chevy's than you'll ever need. /forums/images/graemlins/eek.gif Also, if you'll fill out your profile, it will help us answer your questions. That way we'll know exactly what you're running on your truck.
  3. brando
    Jan 10, 2004
    10
    Gering Nebraska
    Thanks Rick for the input. The axle I have in my Blazer now was rebuilt right before I put it in. The only reason why I don`t think that it is in the axle is the fact that it did the same thing when I had the 1/2 ton axles in it. I have wedges in my spring packs now but do you know where I can get these shims that you are talking about. Also the axle I have in my Blazer now was in a long box chevy for a couple of months and never had a problem then. Thank you!
  4. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    you can get the shims here: AZ kickin'
    I almost definately think your vibration is from your driveline then. You might just need a bigger degree shim to straighten out your pinion to driveshaft angle a little bit. Somebody else will eventually chime in with another opinion, or to backup what I'm saying. /forums/images/graemlins/thumb.gif
    Rick
  5. brando
    Jan 10, 2004
    10
    Gering Nebraska
    Thanks Rick I just may be in touch with you on those shims.
  6. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    just curious, where is Gering, Neb?
  7. brando
    Jan 10, 2004
    10
    Gering Nebraska
    Gering and Scottsbluff are called the twin cities and we are in the far western part of the state called the Panhandle right on the Nebraska and Wyoming boarder
  8. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I was wondering because in february or march of next year i'll be moving just south of Omaha to Offut AFB. I'm going to try and meet up with a lot of guys from Nebraska that are on here. /forums/images/graemlins/thumb.gif
    Rick
  9. brando
    Jan 10, 2004
    10
    Gering Nebraska
    Cool we`ll have to stay in touch
  10. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I've got agree with Rick. Since pulling the rear shaft eliminated the problem, it is most likely the driveline angles. They angles need to be within 1-2 degrees of each other to operate smoothly. Get yourself an angle finder and check how the angles compare. /forums/images/graemlins/thumb.gif
