vibration in steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Jan 6, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    what are typical causes
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    tire balance
  3. tecton
    Dec 1, 2002
    1,553
    WV
    ball joints be an issue?
    the problem seems to have gotten progressively worse
  4. 4wood
    4wood 1/2 ton status
    Jul 27, 2003
    116
    Atlanta, GA
    Check your wheel bearings. After I replaced mine (which were stock), the handling got significantly better.
  5. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    When does it vibrate? All the time? What speed? Some causes I found.... Tires, slightly bent rim, out of balance tires, mud in the inside of the rim can act like a tire weight. What about the drive shaft. If you have the "death wobble" it may be your steering box.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    worn TRE will do this i found out ! you need to do an inspection on your rig, jack up fornt end and check it all out, if nothing is worn sloppy including steering box internals then have the tires checked out
  7. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I'd turn down that 1200w radio...
    that should help... /forums/images/graemlins/tongue.gif
  8. tecton
    Dec 1, 2002
    1,553
    WV
    ok lets see....ive already established that there is a little play in my right wheel, as far as tilting it out and in. The front tires wore down so fast, that i didnt even bother rotating them, cause id rather fix the problem and buy two new tires than rotating them and ruining all 4. The front tires are VERY loud going down the road. Not sure why, alignment? And like i said they are about totallt worn down and my rear tires look brand new still.
