Vibration is killing me
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by flyguy33, Dec 31, 2002.
  1. flyguy33
    flyguy33 Registered Member
    Nov 22, 2002
    10
    Sacramento, Ca and Bay Area, Ca
    Hey guys...I'm new so go easy one me..I just bought an 84 blazer and i'm trying to solve a vibration that i get once i pass up 50mph and up its starts shaking the whole freaking truck so bad i lost my fillings..i've had the wheels balanced and that doesn't seem to be it....I'm thinking it may be that there is a stud missing form the front driveline..seems to have broken off i guess only have 5 out of 6...think this may be the problem? or a loose wheel bearing?
    84 blazer
    3 inch body lift
    /forums/images/graemlins/mad.gif
  2. 4x4 Cowboy
    4x4 Cowboy 1/2 ton status
    Dec 7, 2002
    236
    california
    it could also be if the driveline is to long or short
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    how long has it been since you have changed your driveshaft u-joints? driveshaft could be out of balance too... who knows, balancing weight may have popped off or...?
    does the rig have a lift on it? if so, it could be that there is more angularity in the driveshafts than the ujoints can handle. Might need to shim axles or get a high angle driveline. Just some ideas...
    j
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    psssst...fill out your profile./forums/images/graemlins/thumb.gif
    You're likely to get better responses with your profile filled out. Info on your truck plus a general location helps us help you. Someone might live 3 doors down and could be able to help you out personally...
    Anyways...when did the vibe start? Have you checked your U-joints?
    Rene
  5. J.Lance
    J.Lance 1/2 ton status
    Oct 8, 2002
    145
    Arvada, CO
    I just got done troubleshooting my own vibration. Try to isolate whether you vibration is up front or in the rear. Do a search under my name for posts within the last month, there is some pretty good troubleshooting ideas from the members on those threads. Also, give us some more info. on your vehicle like lift, tires, tranny, etc...
  6. flyguy33
    Nov 22, 2002
    10
    Thanks for your input...So far I've isolated the vibration to the front...The truck only has a 3 inch body lift otherwise the whole truck is pretty stock...I'm thinking a wheel bearing is loose cuz the truck tends to pull to the right when i brake to a full stop not to mention the stock steering stabilizer looks pretty shot...So, i don't know..I checked the driveshafts and it looks like it has been balanced non of the weights look like they fell off ( the welds look pretty new..) and everything else seems to check in (visually looking that is) Oh, and it seems to be leaking in between the tranny end and the transfer case...Is this a hard job to handle? I'm thinking its just a seal, that they didn't put in (no seal visible)....Thanx again /forums/images/graemlins/mad.gif
