vibration....need opinions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 6.2L Jimmy, Nov 19, 2002.
  1. 6.2L Jimmy
    6.2L Jimmy 1/2 ton status
    Jan 2, 2002
    164
    Montreal,Quebec
    Hi All,
    I need help here. Um well it all started about 3 weeks ago for no reason at all my Jimmy started to vibrate above 20-25 mph when under throttle and would die down when I would let off the throttle. Well I brought it to a truck center and they do suspention and U-joints and such and the guy there checked out the front end and alligned it and I went home and it was still vibrating the same. the next day I had to do a short errand and my transfercase yoke (rear)
    snapped at one of the ears and whamo... need a new u-joint and need a new yoke and a balancing (235.00) and the allignment that did not work (65.00) and a towing (75.00).
    So I installed the newly balanced assembly on the truck and it is still doing it but not as severe. The truck is lifted 3.25 inches total front and reer (stock driveshaft)and I have had the lift on for some 6-7 months now and it never did it before,It just started out of the blue. Help please.
    Mike /forums/images/graemlins/k5.gif /forums/images/graemlins/1zhelp.gif
  2. 88k5blaza
    88k5blaza Registered Member
    Oct 17, 2002
    70
    new hampshire
    its probaly the driveshaft U joints from having too sharp of an angle on them
  3. 6.2L Jimmy
    Jan 2, 2002
    164
    Montreal,Quebec
    But it wasnt doing it when I installed the lift and it was on the truck 7 months with no problems. Now I have a new joint ,yoke and balanced . I would understand progressive wear on the joints and it took 7 months to break but all is new now and is still doing it. I am lost.
    Thanks for the reply
    Mike
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You were saying that the truck would vibrate and then die.
    Did you consider the fact that you could have a problem in your engine or tranny?
    A bad tranny would let the engine die, I have had that, and it could make the vibrations.
    And an engine with an imbalance could do the vibrating.
    Just a thought.
  5. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    I think "by dying down" he meant vibration goes away.
    But motor and tranny mounts are worth checking out too since they can cause a vibrations.
    As of out of the blue it starts to vibrate...my puny little mind thinks u-joint, but you changed them and the driveline is balanced? If you don't have the 208 with the slip shaft, just for giggles try inverting your driveline, and make sure the yoke were lined up the same.
  6. 6.2L Jimmy
    Jan 2, 2002
    164
    Montreal,Quebec
    Yeah , sorry bout that .when I said dies down I meant the vibration goes away. Engine is running perfectly and the tranny is only 2.5 years old and seems to be running great.
    Thanks for the replies.
    Mike
