Vibration problem - cured!
Discussion in 'The Garage' started by madmike, Aug 20, 2002.
  1. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    Two weeks ago I posted a question concerning a vibration problem I was having concerning the clutch/engine. Because of the noises I was hearing, the way the engine sometimes felt out of balance, and the way the clutch pedal free play appeared to be changing, and the fact that the clutch is ten years old (no slipping though), I thought for sure I was gonna have to pull the motor to find out what was wrong in the bellhousing area.
    Well, I was laying under the truck while it was running, and I noticed that the engine seemed to vibrate/shake more than the tranny, and then I noticed a gap between the engine and bellhousing on one side of the truck, none on the other. The bellhousing bolts had all become loose, and one was missing!
    I tightened 'em all up, the noises disappeared, the clutch pedal free play is good, no weird vibrations, problem solved! Yeeaahh!
  2. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    I crawl under the truck and look at everything after each run. I usually find something that needs attention. /forums/images/icons/tongue.gif
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Glad you found your problem. Did I notice you said you were underneath it while it was running?
    /forums/images/icons/shocked.gif
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    hope ya put a lock washer on them...
    grant
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Ahhh, Maintenance is the Key. I'm under My Truck Weekly, Looking, Checking, Eyeballing Everything. It Pays off! A little time spent, rolling around under You're rig, will save Massive Headaches Later! /forums/images/icons/shocked.gif
  6. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I had the same problem on my S10! I didnt discover it til I was swapping the tranny...
