vibration problem HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Jun 19, 2003.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    When I am on the freeway or even at 35 mph i am getting a vibration. it seems to be related to speed, not rpm. I assume that rules out the tranny. I have heard it is likely my pinion bearings. is there any other test that can be done to distinguish/rule out tire wear, driveline, pinion bearing or any other possible root to this problem. I suspect that my gear ratio may be too high also. Would this cause vibration problems as well? thanks.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    If the vibe always happens at a specific speed, regardless of what RPMs you're running, it could very likely be driveshaft related.
  3. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    it could be as simple as your tires being out of balance.
  4. blzn1
    blzn1 Registered Member
    Apr 9, 2002
    76
    SO-CAL
    I'm betting driveshaft.
  5. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    Mine does the same thing at the same speed, ever since we lifted it last year. Nothing is binding. It is worse since I broke the rear u-joint and slightly bent the yoke. I'm hoping it goes away when I replace the driveshaft/rear axle this week. I suppose you could take off the rear shaft and drive it in front wheel to help isolate the cause. We lifted the truck on a hoist and while I put it in gear and let off the brake, hubby observed the driveshaft looking a bit like it was going up & down. That was a pretty good indication of a driveshaft problem.
  6. DOCKAWI650
    DOCKAWI650 Registered Member
    Sep 29, 2002
    61
    Gboro, NC
    this happend to my 87 suburban....If it is the same thing, there is a bushing for the driveshaft and this is worn out.
    -doc
  7. mxrcr589
    mxrcr589 1/2 ton status
    Apr 17, 2003
    148
    poop
    blance your tires, or if you got alot of dirt on you rims you might have that problem
  8. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Mine had a pretty rough vibe also. I balanced the tires and I noticed a major difference. I have Swampers and they aren't the easiest to keep balanced. It's kind of a pain.
  9. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    Use Equal (not the sugar substitute either /forums/images/graemlins/tongue.gif) on the inside of the tires. It's expensive but you'll never have to worry about weights flying off, it's self balancing. You'll have to call around to find it though.
  10. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Just be sure to use clean dry air or the stuff will coagulate and not work anymore.
    Moisture is the enemy of equal.
    /forums/images/graemlins/thumb.gif
