Vibration Problem
Discussion in 'The Garage' started by SUB-ZERO, May 24, 2005.
  1. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    My buddy has a 87 Jimmy.We recently installed a 4" suspension lift and 35" BFG's.It seemed to have a slight driveshaft binding but barely noticeable.Just recently(about a month after the lift)we installed a 4 degree shim in the rear. The pinion angle looks good but now it has very noticeable vibration.Help!
  2. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    What are the angles now? Is the driveshaft solid between the joints or does it have slip yoke between them?
  3. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    You need to lower your t-case or get a cv driveshaft. The u-joint angle at the t-case is too high. There are many posts on this issue.
