Vibration Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DPI, Jun 30, 2000.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I have a question for the group. I have a stock 1990 K5 with no lift. I am getting a vibration only under heavy acceleration when the rpms are above 3K. It does not matter what gear its in or how fast I am going. Mileage is are 106K. Any Ideas?
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Did ya check your U-joints?
    89 K5 Silverado
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yep sounds like a Ujoint
    If they are the factory ones the retainers may be the plastic injection type.?? If so you need to use a heat tourch to melt out the little injection holes on both side of the ujoint. When you do this keep your feet back and heat with the hole pointing down and the burning plastic will drip out, turn around and do the tother side.
    Replacements just use the C clips to retain the joint
    Good Luck
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    also check the weights on the drive shaft(s), see if one fell off.
  5. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Also check all your mounts, tranny and motor mounts....
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  6. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
