Vibration under deceleration and a large thump under acceleration
Discussion in 'The Garage' started by juanblzer, Apr 19, 2004.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    alright:
    I have a np208 and i had a bad vibration before I swapped in a 1350CV by Highangledriveline. Within the last couple of mmonths I have heard the t-case hit the floor under acceleration (when the truck shifts into second gear). Withing the last couple of weeks I also noticed a severe vibration/whine under deceleration. I chocked the tires and put the truck into drive and noticed that the driveshaft has some play by the slipyoke of the NP208. I have an extra 208 (so I am not swapping in a 205 and 203)
    Does anyone have any ideas? THe shaft was bought around Sept-Oct of this school year. Warranty? Is it the case? Worn splines? F-d up bearing?
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    What do the t-case mounts look like?
  3. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    well, my t-case crossmember is a custom tube unit. It runs poly bushings on the framerail mounts and a factory t-case mount that actually bolts into the t-case/crossmember. The factory mount feels pretty soft. the polymounts are chewed up on their edges from crawling.
  4. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I wonder if the adapter is broken? /forums/images/graemlins/dunno.gif
  5. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    it doesn't really leak though...
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mine was doing something similar. Right after I installed CV shaft I still had an issue. Turns out my pinion yoke on rearend was loose. Someone must of loosened it at the junkyard I got my 12 bolt from, like they were going to get the yoke. I never checked when axle installed and that was my problem. Don't think it is your problem , but it wont hurt to check it out the play in the yoke. /forums/images/graemlins/k5.gif
  7. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    will do!
  8. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Does your adapter bolt to your crossmember? One or both of the "feet" could be broken. This happened to me on a 82 GMC with a NP208. Since you said the t case hits the floor Im thinking something other than a worn driveshaft is going on....
  9. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    could you explain "feet"?
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Jeff isn't online now , but I believe he meant the pads that sit on crossmember and the trans mount bolts thread into.
    Also when you said transfercase was hitting floor, did you mean it literally , or just sounds like it? /forums/images/graemlins/k5.gif
  11. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    feels like it, its a pretty hard thump...
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well then double check everything mention in this thread. Don't forget to check motor mounts either. Soemtimes the mounts if they are factory rubber will be real mushy and let things move. Check your yokes and u-joints. Also don't overlook the obvious, you could of lost a weight from the shaft if you smacked a rock or something. /forums/images/graemlins/k5.gif
  13. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    first thing first, check all you mounts, engine trans t-case
    then look for any cracks in crossmembers and check all driveshafts for loose or broken yokes the sound you describe makes me think of something shifting position acording to whatever torque is place against it so look for things thatcould move under load /forums/images/graemlins/thumb.gif possibly even your exhaust pipe, ive seen it happen
  14. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep check U joints and all mounts holding drivetrain to chassis
  15. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    okay update!
    I have ORD motor mounts (they are poly and look in decent shape). Last night I took a floor jack and used some pieces of wood and jacked the tranny up. There is some play in the rubber mount that attaches the crossmember to the adapter. OTher than that I really couldn't "see" any damaged or broken pieces. Some of my body mounts have seen better days, Would this make a difference? I'll check exhaust clearance. Any other ideas. I have a buddy who owns a tranny shop. Perhaps I'll take it by.
  16. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I would replace them anyway. I hear you should run poly to match the motor mounts. How much play do you have? When I replaced mine they seriuosly looked and felt like black marshmallows !! If you can get it to that shop for free go for it. A lift helps a lot. /forums/images/graemlins/k5.gif
  17. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Yes, having a shop look at it might be a good idea, if the t case is actually moving enough to hit the floor the problem should be obvious.
