vibration when coasting at highway speed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by basketcase, Oct 20, 2005.
  1. basketcase
    basketcase Registered Member
    Apr 30, 2005
    52
    buffalo,ny
    My 90 v1500 sub has had a slight vibration when coasting since i got it in april 04, but last night i noticed that it is much worse. when i let off the gas at 65-70 mph i feel a vibration from the rear that feels like riding on the rumble strips on the shoulder! i am kind of thinking u joints, anything else that could do this? the truck has 4" blocks in the back 700r4 and 10 bolts(yuck).
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    If you put it in neutral, does the vibration stop?
  3. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    Does it only happen at speeds around 65-70? It could just be a slightly out of balance tire. Check your u-joint, if it checks out fine then you need to shim your pinion up more.
  4. basketcase
    Apr 30, 2005
    52
    buffalo,ny
    vibration coutinues in drive or neutral, it does still vibrate at lower speeds, but nowhere near as badly
  5. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    Do you feel the vibration in the steering wheel or from the rear of the vehicle?
    if it is coming from the front it could be wheel bearings or upper/lower ball joints.If the u-joints check out then it might be the pinion bearing :doah:
    The only small item that wouldn't cost much to check would be to have the driveshaft rebalanced.Hope this helps a little.
  6. mikayak390
    mikayak390 Registered Member
    Mar 3, 2005
    70
    NJ
    My vote is a bad u joint.
    Crawl under it in park and twist the drive shaft side to side. if there is any play the joints are shot. $25 at auto zone and 1/2 hour of time you will be fine.
    Good luck.
  7. basketcase
    Apr 30, 2005
    52
    buffalo,ny
    seems to be coming from the rear, i think. the front bearings are only a few months old.
  8. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    I had something similar last year. For me it was the drivesaft out of balance and it wasted the pinion bearing. The guy who fixed it said I was lucky
  9. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Ditto.
  10. basketcase
    Apr 30, 2005
    52
    buffalo,ny
    how can I tell if the pinion bearing is bad? Is it easy to change? the joints seemed tight when I twisted on the shaft, but I'm tempted to change them anyway. any idea what a driveshaft shop would charge to change the joints and balance the shaft?
  11. tch777
    Jan 15, 2003
    244
    It cost me 75$ to have my driveshaft balanced but I had the diff shop send it to the driveshaft shop to do it so I am sure it got marked up in somewhere.
    My guess is it would cost you around 100 to 120 for them to balance the shaft and swap out u joints. They can also check your pinion bearing too.
    Tim
