Vibration when I let off the gas
Discussion in 'The Garage' started by crroy71, Jun 30, 2002.
  1. crroy71
    crroy71 Registered Member
    Jun 23, 2002
    38
    Mont Belvieu TX
    I have got a vibration (sounds like a helicopter is overhead) when I let off the gas at highway speeds. It does it at all speeds, I am thinking u-joints (not real sure though). Is there any way to check them?
    Thanks,
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    sounds like ujoint to me as well crawl under and try turning your driveline by hand back and forth front and rear of the drive line and you should see if they are bad also you need to park on leavel ground and have it out of gear to do this if you have it in gear it will bind and you wont be able to move the drive line but please chock the tires befor crawling under your truck
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You can also drive it a while then feel the u-joint for excessive heat, if it's hot as hell then the needle bearings are on the way out and you should replace it immediately /forums/images/icons/frown.gif
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    either the joints... or the angle your shafts are operating at is to much for the joints and you need a trick shaft. You didn't say whether or not you lifted your rig recently so...
    J
  5. crroy71
    Jun 23, 2002
    38
    Mont Belvieu TX
    I bought all new u-joints, for front and back shafts, and the wheel joints. Figured while I'm under there I might as well do it all. Any tips or tricks on changing any of them?
    I am also thinking of changing the front wheel bearings while I'm at it, how do I tell if they are good or bad?
    Thanks,
