vibration ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wnderbra, Feb 26, 2001.
  1. wnderbra
    wnderbra Registered Member
    Feb 18, 2000
    47
    Virginia
    I just recently put a 6in lift on my blazer and shackle kit in rear. Quick question but hard to explain. The front driveshaft was hitting the crossmember when I stomped the throttle The marks on the driveshaft where minor so I removed the old bushings and replaced with energy suspensions and gently massasged the crossmember for a bit more clearance. So here's the question Everything bolted up smooth but when I drove it the seems to be a new vibration .It is mild but I can feel it ,nothing changed but the bushings.Could it just feel different because of the new bushings opposed to the old soft rubbers? There was no vibration after installing lift. Maybe somebody knows what I'm talking about if not join the club
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Energy Suspension mounts are a bit firmer than the factory rubber. Possibility that the vibration was there before and the new mounts are just transmitting the vibration through the frame. Also, did you do anything to the drive shaft after the lift? Mine had to be lengthened after a 4" lift. They may not have enough of the splined area engaging and causing the center to wobble around a little. Just a thought.
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Did you drop the t-case? Also from what I have read you need about an inch more on the front d-shaft (Superlift makes a 1" spacer). Also some people have said the CV on the front shaft sometimes needs to be grinded a bit or it binds.
    1987 Chevy K5 Blazer- 350 TBI
