vibration
Discussion in 'The Garage' started by BT, Jan 4, 2006.
  1. BT
    BT Registered Member
    Jan 4, 2006
    43
    Texas
    Another question... My truck has a 4" or 6" trailmaster lift. It was on the truck when I bought it so I am not sure exactly how tall. It does fit 35" tires easily and has never rubbed anywhere. I am thinking it is 6". The truck has had a bad driveline vibration since I bought it. I have had the tranfer case rebuilt, all new driveshafts built and balanced, new slip yoke, shimmed the rear axle, and it still has a vibration above around 60 mph. Sucks to drive on highway because of this. I saw an ad for a slip yoke w/ cv joint in a wheeling magazine. It did help when I shimmed the rear axle. I was thinking about trying a few more degree shim. I have the carpet out of the truck with line-x sprayed in interior so all road noise and vibrations are noticed. Help?
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    When I had my K5 I always had vibes and went through U-Joints quick. Lowered the T-case and shimmed the axle. The only thing that I did that got rid of the vibes was a 1350 CV driveshaft. That thing was awesome!!
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    drop your t-case, get a slip yoke eliminator, cv flange-yoke.......just some options.
  4. BT
    Jan 4, 2006
    43
    Texas
    The lift came with some spacers to drop the transfer case. where do you get the cv drive shaft? slip yoke eliminator? I wil try it.
  5. trailblazr81
    May 27, 2005
    931
    Hollister, CA
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Where in Texas are you? Swing by my house and we will get you fixed up.
  7. BT
    Jan 4, 2006
    43
    Texas
    I am in Mansfield (work) Midlothian (home) Where are you. If you want to look at it that would be cool. Thanks... Brent
