Vibration
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by newGenk5, Sep 18, 2001.
  1. newGenk5
    newGenk5 Registered Member
    Sep 14, 2001
    36
    Sacramento, CA
    hmmm.....my 72 k5 4w vibrates when i gas it....
    i can cruise at 50 in nuetral wiht no vibration(smooth)
    but when i give a little gas vibration all over the truck. so i replaced the rear ujoint and still vibrates
    any suggestion
    here are some pictures of the front u joint that i did not replace, seem okay to you guys
    [link=http://64.172.156.16/k5/ujoint/]pictures of front ujoing[/link]
    or select this and paste into browser
    i appreciate any help
    keep on rollin
    check it out[/link]
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Hard to tell visually if it's OK or not. I'd jack up the rear end (support it on stands, release the parking brake) put the truck in gear (or Park if it's got a slush-box) and grab the output yoke of the transfer case in one hand, the driveshaft in the other and twist the yoke and shaft in opposite directions a few times to see if there is any play in that U-joint. If there's play, it's bad. If there's basically no play, it's good. This problem does sound like a universal joint problem, since it appears under power and goes away when not under power.
  3. newGenk5
    Sep 14, 2001
    36
    Sacramento, CA
  4. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Clicky
    <a target="_blank" href=http://64.172.156.16/k5/ujoint/>pictures of front ujoing</a>
    <a target="_blank" href=http://64.172.156.16/k5>check it out</a>
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  5. newGenk5
    Sep 14, 2001
    36
    Sacramento, CA
    well it was the front.......took it out again and replaced the front, rear replaced the day before....runs like a charm.
    thanks for fixing the link i made. still cant get it to work
    oh well
    keep on rollin
    check it out[/link]
