Vibration
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Oct 22, 2002.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    I am getting a pretty bad vibration at around 70 and higher. Recently the U-joint lost 2 c-clips and worked itself a little loose. I fixed it, swapped rear tires to the front and I still have this vibration in the rear. The u-joint is tight, but could it have gone bad or worn itself out of round when it came loose? Am I expecting too much if I want the truck to be smooth, or close to it at 75? Truck is in the sig.
    AW
  2. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
  3. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    I would change the ujoint as a precaution. I had a vibe in my blazer for a couple days. It wasn't that bad, so I thought it was alignment. After a couple days I busted the ujoint & messed up my driveshaft.
  4. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    Ya, I'd change that U-joint first too. Be sure and not overtorque them or the cups will get out of round, needle bearing melt, then you throw/pole-vualt the driveline. After changing that joint and it still vibrates, take the driveline to a driveline shop and have them check the balance. Also, when your driving and the paint is pealing back, you're going too fast...
    You might also want to do a search on 'Vibration' and all post older thatn a year and you should come up with some similarities
  5. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Try and find an EVA meter. It will measure the vibration frequency and from there you can pinpoint the source.
  6. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Where would one obtain such a meter at a reasonable price?
    /forums/images/graemlins/burb.gif
  7. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    I've got the same thing happening in my 84. Don't know if this has anything to do with it, but jack up the rear, take off the wheels and rotors, and let it idle in drive. If you have a semi floating rear, watch the axle flanges. I tried to fix my vibration prob. for about 6 months and couldn't find anything. When I happened to have the rear up to check for rear bearing noise when I noticed some wobble in one of my flanges. Turns out it's bent. I must have hit something harder than I thought. Like I said, That might not be it, but it's easy to check.
  8. Tice
    Tice Registered Member
    Aug 24, 2002
    36
    southeastern arizona
    i was having that same problem, but at a lower speed and i was eating u-joints like dog on a bone. turned out to be a bad yoke. havnt had any problems in over a year. good luck. Tice /forums/images/graemlins/k5.gif
