Vibrations... Yikes!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Topdown, May 1, 2005.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Ok... so I put a new rearend in my 72 the other weekend. The new rearend looks good, bearings felt fine, gear mesh looks perfect, etc...
    When I am driving down the road, there is a very slight vibration... not a big one until i get to about 45 (where it gets much more pronounced) and it lasts until about 52 or so then pretty well goes away. that is until I am slowing down and then from about 12 down to about 2 I get a very pronounced vibration, as I slow, it slows until I come to a stop or accelerate again.
    Now... the rearend that I put in, had a different pinion than the one I took out, as in the one I took out was an original 72, the one I put in was out of a late 70's or 80's truck. Also, the spring pads are taller on the new axle so it lifted the rearend another 1/2 inch or so.
    Other items of note... my driveline is pretty well fully extended and then some. the teeth are showing out the end of slip by about 1/2 inch.
    So... I know I need a new driveline, dont bother telling me that. What I want to know is: Since I have never had a driveline vibe before, is that what I am experiencing? I have 3" of lift in the rear and my pionion angle doesnt look bad but I am at a loss as to what would cause the vibration.
    Any help would be appreciated.
    -Ryan
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Maby your tires are out-a-wack? That happen to me once...
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    did you swap tires from side to side? it could be a radial vibration had it happen once and when I swapped the fronts from side to side the vibration went away. New axle have a bent axle shaft?
  4. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    Driveshaft
    Driveshaft
    Driveshaft
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I've seen simular vibes from loose yokes on either trans or rearend on big rigs.
