Vibrations
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jojospastic, Aug 21, 2002.
  1. jojospastic
    jojospastic Newbie
    Aug 21, 2002
    New Jersy ,USA
    OK the problem that i am having is my truck vibrates from 25mph to as fast as it goes. it does not get worse as i go faster. i have a 4 in rancho lift and 33's.i have the largest degree shims that i can get on the rear axel. and i had a t case lowering kit for a 4 in lift but i swapped it out for a tcase lowering kit for a 6 in lift. and i still had the vibration. so i got a cv drive shaft from arizona driveline and i took the tcase lowering kit out. now i still have a littel vibration and i cant figure out where it is coming from. i am thinking the trany or the tcase any sugestions. /forums/images/icons/confused.gif
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Welcome aboard...it could be anything from a U-joint to a tire out of balance. /forums/images/icons/ooo.gif
