video of lasic eye sugery!
Discussion in 'The Lounge' started by supersize75k5, Jan 28, 2007.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
  2. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
  3. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    WOW! Looks dangerous! Crazy. Thanks for sharing.
  4. 68MUDSTUD
    68MUDSTUD OCD with shiny things
    Sep 30, 2005
    9,448
    MT
    is that how long it takes? I was always under the impression that it took like an hour per eye...
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Nope, doesn't take long at all. The newest ones have computers that feed back to the laser in pikosecond time tracking your eye....which means you could essentially be looking around the room and it'd still do a perfect job.
  6. 68MUDSTUD
    Sep 30, 2005
    9,448
    MT
    thats insane...
  7. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    better then the origonal.
    first started they would use a knife to cut a * on your eye, and it would heal flater, corecting the lense, later they cut a flat off the eye then cut it and floded the flap back to speed healing.
    i think lasers are better. :D
    but then again i have 20/15 so....
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Radial Keratotamies (sp?) are sort of a thing of the past with lasik now but they're still performed occasionally. The problem with them is you have to make a cut like 95% of the depth of the cornea. Too shallow, and nothing happens, too deep and there's a good chance you'll be blind.
  9. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    I had lasik done 3 years ago. Best damn $3000 I have ever spent. Was on the table less than 7 minutes. Went down no being able to see the big E sat up reading 20/25 ended up being able to see 20/15.
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    If you're under 40 or so when you want the surgery, just make sure you understand the risks that age imposes on your corrected vision.
  11. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    That was pretty...gross? I'm fine with it, but watching it made me queasy. I was just imagining the eyeball popping or something... :puke:
  12. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    You should see the surgical technique videos my dad watches where there's a scalpal and a couple other instruments digging around in there. :D
  13. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    I would respond in an intelligent manner, but I'm having trouble reading this.
  14. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I did not need to see that, the 15 seconds I watched..........
    Shut up:mad::eek1::doah:
  15. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    why does being under 40 have an effect? im 20 and have been considering this for a while now and(belive it or not) seeing that actauly gave me a little more confidence.
  16. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Basically, when you get to around 40 your eye gets lazy and doesn't like to focus on a variety of ranges anymore. A lot of people that have had good vision their whole life develop a certain amount of either nearsightedness or farsightedness as they age. In a normal person wearing glasses this would just change their perscription, but for some people with lasik it can put them back into glasses, which is what you paid big money to avoid. I'm not sure if the surgery can be retouched as your prescription changes, but I can certainly ask.
  17. Stomper
    May 11, 2002
    3,767
    Iowa
    I believe you can have "touch up" work done. I'm planning on getting it next month:eek1:
    That's why I didn't need to see that:haha:
  18. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Well just hope you don't ever get cataracts then...good luck with the sharp pointy objects. :D
