VIN code Information here
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyracing, Dec 16, 2002.
  1. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    1967-1972 VIN Number Codes
    Example: CE149J 100001
    Chassis Designation (1st digit)
    C= 4x2
    K= 4x4
    Engine Deisgnation (2nd digit)
    E = V-8 Gas
    S = Six Cylinder Gas
    GVW Range (3rd Digit)
    1 = 1/2 Ton
    2 = 3/4 Ton
    3 = 1 Ton
    Model Code (4th Digit)
    4 = Pickup with Cab and Bed
    Model Year (5th Digit)
    7 = 1967
    8 = 1968
    9 = 1969
    0 = 1970
    1 = 1971
    2 = 1972
    Assembly Plant
    A = Atlanta
    B = Baltimore
    F = Flint
    J = Janesville
    N = Norwood
    P = Pontiac
    S = St. Louis
    T = Tarrytown
    Z = Fremont
    1 = Oshawa
    Vehicle Serial Number
    100001 = 1st Unit Built
    1967-1972 Model Number Codes
    (The Model Number is located on the inside of the glove box door.)
    Example: C E 1 09 9 34 J 100001
    C = 4x2
    K = 4x4
    P = Forward Control
    E = V-8 Gas
    1 = 1/2 Ton
    2 = 3/4 Ton
    3 = 1 Ton
    Cab To Axle Dimension (4th Digit)
    07 = 42"-47"
    09 = 54"-59"
    10 = 60"-65"
    12 = 72"-77"
    13 = 78"-83"
    14 = 84"-89"
    15 = 90"-95"
    7 - 1967
    8 - 1968
    9 - 1969
    0 - 1970
    1 - 1971
    2 - 1972
    Body and Brake (6th Digit)
    02 = Flat Face Cowl
    03 = Cab
    04 = Stepside Pickup
    05 = Panel
    06 = Suburban
    09 = Cab, Platform, and Stake Rack
    12 = Windshield Cowl
    16 = Suburban (Tail and Liftgate)
    26 = Custom Suburban (Panel Rear Doors)
    34 = Fleetside Pickup
    35 = Foward Control (Square Front)
    36 = Deluxe Suburban (Panel Rear Doors)
    42 = Forward Control Chassis
    45 = Forward Control Panel (Round Front)
    Assembly Plant
    A = Atlanta
    B = Baltimore
    F = Flint
    J = Janesville
    N = Norwood
    P = Pontiac (GM Truck)
    S = St. Louis
    T = Tarrytown
    Z = Fremont
    1 = Oshawa, Ont., Can.
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    year digit is not part of the model codes, IE CE109934 is actually CE10934
    and in 72 the VIN code received extra letter at beginning of the VIN, for conventional cab trucks they got an extra C at the beginning so a V8 blazer in 72 VIn begins with CKE or 6 cyl one CKS
    and the "4"th digit can also be a 3 which is a chassi cab, then there stake model and cowl windshield model, etc etc so forth and they each have a different digit
    and all these codes only apply to chevy btw, GMC has a whole different code system
