  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    VIN\'s
    I need to know how to read vin's escally engine trans and axles. I no people may have changed this stuff along the way but this way I can tell if they have. Any other Vin stuff would be appricated also
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Re: VIN\'s
    In the front of an LMC catalog it'll tell you chassis and engine VINS
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Re: VIN\'s
    Whats a LMC catalog?
  4. Jed
    Jed Registered Member
    Nov 3, 2001
    60
    Alberta, Canada
    Re: VIN\'s
    Truck VIN can be found on plate on the top of driver's side dashboard or driver's door pillar. Some people have also found a vin on top of the frame rail by the power steering pump (on older trucks).
    If you search the web for "vin decoder chevy truck" you'll probably find a site that tells you how to decipher the VIN so you can find out what engine it had, GVW, 2 or 4 wd, 1/2, 3/4, 1 ton and the year of the truck. The 70-87 chilton's manual for these trucks also has a VIN decoder.
    Also look in the glove compartment for a list of options that originally came with the truck. You can probably find the definition of these codes on the web too.
    You're right about things being swapped in and out tho - the vehicle VIN and options sticker will only tell you the original goodies that went with the *body* (unless you find a the vin on the frame). My truck's VIN tells me it's a 1987 2wd 1/2 ton with a V6! That's probably why the body's in great shape - but it actually has sb400, th400, np205, 14bFF.
    Your best bet is being able to visually identify the transmissions, transfer cases and axles. Advanceadapters.com has a good description of how to id lots of parts like the xfer cases and trannies. Pirate off road also has a good tech section that tell you what axles, trannies and xfer cases you can expect to find in a given truck.
    Engines are a bit harder - a smallblock 305, 350 and 400 look pretty much the same. Big blocks are pretty easy to spot by the valve covers. The best way to id a smallblock is to take a rag and wipe the crud off the front of the passenger side head and block where the head gasket is - on the block surface there (facing up) and sticking out forward of the head will be some numbers that tell you what the engine is. Search the web and you'll find a quite a few chevy smallblock code decoders. I was suprised when I found out that my truck had a 400sb.
    Given all the info on the web, the only difficulty I had was differentiating between a GM 10 bolt and a dana 44 front axle. All the diff cover gasket pictures I found on the web showed a rear 10 bolt which (to me at least) looks basically round. The front 10 bolt has a slope on the top driver's side like the dana 44 (which also has 10 bolts on its cover). Scrape the crud off the driver's side 'webs' on the diff housing and look for some letters. My 10 bolt had GM 85 instead of "44" or whatever Dana puts there (I'd guess the 85 means 8.5" ring gear). No bigge between these axles anyway - they're pretty similar strength-wise from what I hear.
    It's handy to have printouts of VIN and engine code decoders along when you go to look at a truck.
  5. chevyfumes
    Feb 24, 2000
    38,584
    266
  6. Sinful_Nature
    Sinful_Nature Registered Member
    Jun 14, 2002
    90
    Raymond, NH
    Re: VIN\'s
    Clinton's usually has pretty good decoders.
    ~Russ
  7. dyeager535
    26,979
    Re: VIN\'s
    Not sure when GM quit stamping it, but the frame has partial VIN (for certain, meaning I've seen it) either near the steering box on the top, or under the drivers seat on the frame top.
    "Early" trucks would have it on the frame near the box or on the opposite side (apparently, thats where they looked when the state patrol inspected my truck) while my '81 has it on the top of the frame, under the drivers seat.
    For certain about '87 or '88 GM stopped partial VIN stamping the frame on full frame cars, I'd imagine trucks would be similar.
    It's only a partial VIN though AFAIK (like the engine) so you can't garner much info off of it, except whether the frame matches the body.
    In case anyone was curious of course : )
