Vinyl floormat and insulation stuff, keep or loose?
Discussion in 'Interior - Stock & Custom' started by AJMBLAZER, Mar 23, 2007.
  1. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    My CUCV has the vinyl/rubber floor mat and the insulation stuff under it. The insulation is SOAKED and I want to remove it completely.
    How do you take the plastic surround dohickey off of the 208's shifter? The part that sits on the floor and has the gear indicator on it.
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    there should be small screws in the front and back of it. unscrew them and it will slide off.
  3. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    There are philips head screws at the front and rear of the plastic cover. Remove those and it should lift right off.
  4. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    You beat me to it:)
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Don't forget the shifter knob gets unthreaded , but thats common sense :thumb:
  6. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    Cool, thanks guys.
    Now should I keep the vinyl flooring down there and just get rid of the insulation or get rid of both?
    The eventual plan is to Herculine (or something similar) the floor and maybe the vinyl on top of that. Too broke right now though.
  7. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    I yanked my mat and liner this last weekend. The rubber mats are notorious for trapping water and causing rust. The more I think about it, the better Line-X, Rhino, etc., sounds. I like the idea of a hose out interior. IDK, like you, it's going to be awhile before I have the dough to get it done, but I plan on doing the prep myself, which usually saves a little money and lets me know it's done right.
  8. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    My problem seems to have been all the little mounting holes the military put in the floorboards and the place that I bought the truck from never filled...:rolleyes:
    I'm thinking about just running the vinyl floormat for now to at least keep the dirty feet off of the floorboards.
  9. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    With my M1028 I plan on ditching the insulation and keeping the vinyl. I will put a layer of eDead or Peal & Stick under the vinyl for sound and heat control.
    On the overhand, if I had the money for Line-X or Rhino liner I would get that.
  10. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    I pulled the vinyl back up to the tranny hump and pulled the insulation out.
    This thing hasn't been in wet weather for a few weeks and has had new door weatherstipping for about as long...the insulation was still wet. REALLY wet on the d-side.
    Also found a small hole on the p-side from where they ripped out the bio-warfare sensor thingy's floor mount. Nothing a dollup of RTV and a penny couldn't fix for the time being.:laugh:
  11. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    Here is what the Military manual says....
    TB 43-0213
    DEPARTMENT OF THE ARMY TECHNICAL BULLETIN
    CORROSION PREVENTION AND CONTROL
    (6) Floormat.
    (a) After removing floormat, discard padding and apply nonslip flight deck compound (NSN 5610-00-782-5556 1-gal. kit).
    (b) Install rubber mat without padding.
  12. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    Cool. Thanks.
    Kinda looks like there was non-skid all over the floor on this. I was thinking that it was some sort of carpet stick stuff but now that you mention the non-skid it does remind me of that.
    I'm still going to Herculine it or something.
  13. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    I have read in other threads where they said it made it hotter inside without the mat and I know the hump in mine will melt the kids Reese's pieces in September (no heater on). I know first hand with out the rear one in mine it is louder (more road noise).
    I want some now that I thought of them!
  14. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    Yeah, I know a guy that restored a '84 K10 and he discovered much to his dismay that the Herculining didn't do anything to retain heat, block heat, or dampen sound.:doah:
    I don't think the 305 stroker or the dual straight pipes helped any though.
