Visual Differances Between d60 and corp 14bolt?
Discussion in 'The Garage' started by K5on38s, Jan 26, 2003.
  1. K5on38s
    K5on38s Registered Member
    Dec 11, 2002
    90
    Buffalo, NY
    i have a 14bolt FF and the pple i got it from said it was a corp14 bolt and then a couple people i know said its a dana???? any visual ways to tell....other than serial #'s ???????
  2. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    If it's a full floater (and a full floater) the pinion is in a removable pinion support like a Ford 9" axle. You would see a round 8 bolt pattern close to the yoke, remove these bolts and the pinion and support assembly will pull out.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Count the diff cover bolts, 14 on the 14 bolt, 10 on the D60. </font color>
  4. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Unless you got the good one the axles are bigger in 14B.Dito on Cover bolts. /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  5. K5on38s
    Dec 11, 2002
    90
    Buffalo, NY
    ok well its got 14 bolt cover, and its got bolts around the pinion... so its a corp right?
  6. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    yes sir
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    yup. its a 14 bolt FF
    grant
  8. ZonkRat
    Jan 16, 2003
    1,003
    Like 14B cause more of then around.In GMs from bout 73 till 98 or so.More spare parts.Detroits can be got for bout $300 too. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    there are way more dana 60 rear axles IMO
    dodge and ford both used them for about a hundred years
