Visual ques between 454 and 502, can I tell the diffrence
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Jun 21, 2003.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Looking at a 92 3/4 GMC. Dam valve covers are 502's but is the motor?
  2. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    Externally they are identical. The quickest way I know of to tell is to pull a head and measure the bore. 454 is 4.25" 502 is 4.5" (4.47" to be exact). A stock 92 should have a gen V big block. Here are the differences between the 3 generations of Chevy big block.
    Gen IV: Mechanical fuel pump boss, 2- piece rear main seal, adjustable valvetrain.
    Gen IV is 454 only
    Gen V: No mechanical fuel pump boss, 1-piece rear main seal, non-adjustable valvetrain.
    Gen V can be either 454 or 502
    Gen VI: Mechanical fuel pump boss, one-piece rear main seal, non-adjustable valvetrain,
    Gen VI can be either 454 or 502
    You can use the valvetrain to positively identify gen IV from gen V/VI engines but that won't tell you if you have a 502 or a 454.
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Actually, the quickest way would be to look at the numbers on the back of the block and compare them with this list: Big block casting numbers
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    or knock oput a freeze plug and check if it has siamiesed cylinder walls...if it does, it is a 502...
    Chris
  5. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    Shouldn't a 92 block have 7.4L stamped on the drivers side of the block??
    Mike
  6. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    The 7.4 / 454 will have "7.4L" cast on the side of the block.in front of the starter....in 2 or 3 inch high lettering.... Can't miss it...no exceptions... /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
