Voltage questions
Discussion in 'The Garage' started by BIG*RED, Dec 20, 2005.
  1. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    everytime I start my blazer the Battery guage reads low, and it stays that way until I "rap" the gas, and get the rpms up to about 2000.
    I have heard that this is quite common on older chevys, has any one else experienced this? and has anyone figured out a way to fix this?
    I have replaced all my wireing, (painless kit) and even upgraded to a "high output" alternator wireing package also from painless, and this hasn't changed anything.
    another question...
    Is there a thing as to much voltage?
    I have a slightly stronger than stock alt. its an 80amp alt and when I hook up the ol tester while the truck is running and i'm getting 15.1 volts at the battery. and when I flip the switch to charge both batteries at the same time, i get 14.8 volts at both batteries.
    is that ok voltage? or is that to much?
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    voltage is a little high, i wouldn't worry as long as it doesn't go higher
    is it a stock type alt., or a 1 wire(self-exiting)?
  3. BIG*RED
    Mar 14, 2003
    1,094
    yes its a stock type alt, just steped up from the 60amp to the 80amp
