voltage setting for TPS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Obsession, May 17, 2002.
  1. Blazin Obsession
    Blazin Obsession Registered Member
    Sep 25, 2001
    64
    B.C Canada
    I have an 88 Blazer and have to set up the throttle position sensor on a Holley TBI, can someone tell me what the voltage should be at idle?
    Ken
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Not 100% sure on your's but a typical TPI TPS setting is .54 +/- .07. I'm sure someone with TBI will chime in............
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    BlazzinOR was close, but his dyslexia kicked in. /forums/images/icons/wink.gif 0.45 volts is what you're looking for in the idle position. /forums/images/icons/cool.gif
  4. Blazin Obsession
    Sep 25, 2001
    64
    B.C Canada
    Thanks for the help
    Ken
  5. BurbinOR
    5,829
    Oregon
    Umm, no................TPI is .54.............
  6. Blazin Obsession
    Sep 25, 2001
    64
    B.C Canada
    I tried both ways and the correct setting seems to be .54 volts.
    thanks
    Ken
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I just looked up the specs in a factory service manual for '87 trucks. It says .60 volts for all TBI V8's. Go figure... /forums/images/icons/blush.gif And yep, the '87 'vette manual calls for .54 volts, just as Frank said. I had the .45 stuck in my mind and now it's driving me crazy that I can't think of where I read it! /forums/images/icons/cool.gif
