Voltimeter/Regulator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78Jimmyish, Aug 17, 2001.
  1. 78Jimmyish
    78Jimmyish 1/2 ton status
    Jul 28, 2001
    137
    Rhode Island
    My voltimeter fluctuates quite a bit when I'm driving. At idle it sits right at 12/13, but when I'm driving it fluctuates from about 10/11 to 15/16 - never hits near the red on either end, but if I'm driving at night with the headlights on they dim and brighten as the meter fluxes. Does that sound like the regulator or something else?
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Sounds like either a bad gauge or yea, the voltage regulator is messing up.
    '73 K5
    Chevy good...Ford bad
  3. dyeager535
    26,982
    191
    Get a voltemeter (actual seperate one) and hook it up to the battery, and watch it as you rev the motor up, turn on lights, etc. If you get a lot of jumping, its an alternator problem. If its pretty steady (although it will go down under load to maybe 12.5 or so ideally) then it would be in the gauge.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  4. 78Jimmyish
    Jul 28, 2001
    137
    Rhode Island
    Cool, I have a voltimeter. If I hook it up to the battery and it jumps (matches the gauge) should I replace the regulator first, or is it the alternator for sure?
  5. dyeager535
    26,982
    191
    Well, I'm not totally sure, so I can't with certainty say. i just don't know enough about the alternators to know if that problem would be regulator. My guess is yes, but am I positive? No. I believe you can get rebuild kits for $15-20, and they are easy to do.I believe you replace most everything that wears out (typically) in the alternators with one of the kits.
    Dorian
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    ethier way it is easier and more cost efective to start at the regulator.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  7. 78Jimmyish
    Jul 28, 2001
    137
    Rhode Island
    Yeah, that makes sense. I'd rather replace the $15 regulator first.
