Voltmeter/Ampmeter whatever the gauge in the dash is, going nuts
Discussion in 'The Garage' started by k20, Jul 8, 2004.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Ok ive noticed that if Im runnin along steady speed on highway, 65 or so for extended periods (noticed today cause had nice long drive to jobsite) that my voltmeter or ampmeter or whatever the stock dash gauge is called, would start falling over to low side (has an 8 13(12maybe) and 18 on the gauge, and it would fall to just above yellow area. However, if i adjusted speed, faster or slower it would go back up to normal, sometimes it would just pop back up on its own. Idling in traffic and all it was fine. What gives? ALternator going bad (rebuilt around a yr ago), bad gauge, what?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Could be alternator going , or bad wiring to batt. Find out now, if its running on alternator and not charging battery, or if its running on battery , sooner or later it will drain enough to not crank the engine. Just have the battery and alternator checked, before you replace the gauge /forums/images/graemlins/k5.gif
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    well i doubt its running on the batt, fuel injection, msd, fuel pumps... for 50 miles up interstate, 50 miles back, stop & go traffic included. Also how would i check that the alt is working prop if it just f's up every little bit? like i mean it might take 20mins b4 it does it again, at 65mph lol.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well you could run it for a while with a multimeter hooked up and see what you get, you obviously cant do it while driving , but measure the battery before you start and run it , and after it is running . perhaps let it run awhile and see if it does it on the gauge and doesn't on the multimeter . Also do it on the fusebox on an ign source /forums/images/graemlins/k5.gif
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I dont know what your problem is, but the oil pressure gauage in my Jimmy went wild last winter, it would spin around like it was a pysco
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Test the alt with a load tester, my guage is off for some reason and moves around a lot especially with the system going.
  7. dyeager535
    26,982
    191
    I just read a thread on another board where someones GM alternator was doing similar, except that it would start overcharging, then fall back to normal, randomly.
    Turned out it was the voltage regulator, even though it tested good.
    If it's a free replacement, turn it in and see I guess. Having it tested might work, but depending on how intermittent, they might not see the problem either. I hate that. If not, a rebuild kit with a new regulator is about $20, and easy to do.
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ]Mine did that exact thing when my voltage reg. went out a few weeks ago in my alt...easy diagnosis IMHO.
  9. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    ok update, tested it somewhat just a bit ago. Voltage at the batt was 12.6 with truck off, start it, 14.6volts. I let it warm up, still same, so shut it off, wait a min start it back, then its 13.6v. WTF. How does it drop a volt in that short bit, that add any clues to the mystery?
