Volvo Portal Axels
Discussion in 'The Garage' started by IronMan, Jul 16, 2003.
  1. IronMan
    IronMan 1/2 ton status
    Nov 16, 2002
    223
    Bay Area, CA
    Anyone know a good source to purchase volvo c303 portal axels? OffRoad General Store has them, but he wants 6k a axel. I hope to find a cheaper pair somewhere. I am going to put them on my Toyota (yes I've heard the jokes). But you can't argue with almost 18" of ground clearance under the diff with 37" tires.
  2. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    You probably have, but have you given any thought to mogs?? They are easy to find and alot less than 6K per axle. /forums/images/graemlins/eek.gif
    Eric
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    check with Don Henry over on the pirate board. he had some 406's that he redid that were ready to be dropped in. pretty sure he'll be able to get some 303's, but he had alot of the 'Mog 404's a few months back.
  4. IronMan
    Nov 16, 2002
    223
    Bay Area, CA
    Mog axels are offset, one passenger one driver side. They take more fabrication to put in. And they weigh a considerable amount more than the volvo's. The c303 axels are 1 ton rated, perfect for a yota or jeep. Offroad General had cv joints that replace the birfiels. And all come with lockers. Just weld some spring pads and shock mounts on. The only downside is the steep gearing (7.14) and the funky bolt pattern. But I'm getting new rims anyway. I think instead of running a dual t-case setup, I will just run another Overdrive. When on the trail, I'll just disengage the OD. Also it provides you with a couple of inches of lift just bolting them on. I think portals are the way to go if your going to put axels on a vehicle. Thanks for the info /forums/images/graemlins/thumb.gif
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I'm assuming the Volvo axles do not have torque tubes. If so, that's an other thing you'd have to convert with Unimog axles...
