Vortec 5300 & 5700 Displacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadBowTie, Aug 22, 2000.
  1. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
    Trying to settle an argument. The Vortec 5300 is still a 305 & the Vortec 5700 is still a 350 correct? Some body's trying to tell me they have a 325-327 Vortec in their '99 Silverado. Any web site that has the info would be great, All I can find on Chevy's is the HP, not the displacement
    <font color=purple>Rick
    86 K-5</font color=purple>
    http://www.BigBadBowTie.ColoradoK5.com
  2. BigBadBowTie
    Apr 6, 2000
    160
    AZ
    Follow up! The GM site lists the followin gengine choices only for a 1/2 ton.
    Vortec 4300 V6
    200 HP @ 4600 RPM
    260 LB-FT @ 2800 RPM (Torque)
    Vortec 4800 V8
    270 HP @ 5200 RPM
    285 LB-FT @ 4000 RPM (Torque)
    Vortec 5300 V8
    285 HP @ 5200 RPM
    325 LB-FT @ 4000 RPM (Torque)
  3. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    I believe you are both right. The 5300 is actually a new design 327 chevy while the 5700 is a 350. Think of it like
    this. 5300 equals 5.3 liter equals 327ci. 5700 equals 5.7 liter equals 350ci. I hope that settles your arguement.
    MUDNUT
  4. BigBadBowTie
    Apr 6, 2000
    160
    AZ
  5. BigBadBowTie
    Apr 6, 2000
    160
    AZ
    That's what I always thought, ecept I thought the 5300 was a 305. But, according to what I've come up with the 5300 is the largets motor available in a 1/2 ton!
  6. Brians 60s
    Jun 12, 2000
    1,115
    Bend, Oregon
    That may be true 5300 may be the largest motor available. I would like to think that is not the case but I am not sure on that one. Sorry
    MUDNUT
  7. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    They still make a 350, 5.7 liter small block, (it's really 346 ci, but they call it a 350), but only for the f-bodies and corvettes. The corvette motor makes 345 hp and the camaro/firebird's makes 325. They aren't making trucks with this displacement engine at all. The available engines are:
    4800, 4.8L, about 293 ci
    5300, 5.3L, about 327 ci
    6000, 6.0L, about 366 ci, (3/4 ton only)
    8200, 8.2L, about 492 ci, (to be offered in 2001 models, based on a stroked 454).
    So, you can still get a 350 but only out of a camaro or corvette and the 5.3 is factory rated at 270 hp.
    I'm holding out for the 8200 with the 5-speed Allison Automatic behind it. BULLETPROOF!!!
    HTH,
    Buddy
    I've got my dream truck and it's a 72 K-5 that is getting there!!
  8. Jamie
    Jamie Registered Member
    47
    Johnstown PA.
    There still putting the 350's in some of the commercial vehicals and work vans.
  9. Captkaos
    Captkaos 1/2 ton status
    198
    Birmingham, AL
    Last year for the 5.7L
    The last year for the 5.7L was 1999. It was replaced with the new motors based on the GEN3 SBC, the LS1. The 350 is still being used on some commercial vehicles, but plan on them being replaced eventually.
    The largest motor availible in the new 1/2 tons is the 5300, which by the way is a 325, not a 327.
    Just being technical, but there is approx 61.5L per cubic inch. 5.3L = 325.95. The displacment of the motor is 96mm (3.7795") x 92mm(3.622") Which comes out to 325.08... GM rounded it up to the nearest 10th to get 5300. In addition the 305 is a 5.0L motor.
    For more info on it and other GM motors, check here:
    http://www.gmpowertrain.com/engines_cartruck/vortec_silver/53_main.htm
    Can you tell I am bored right now at work?
    Chris Lucas
    http://www.captkaoscustoms.com
  10. 86blazerk5
    86blazerk5 1/2 ton status
    Aug 9, 2000
    387
    Hagarstown, Maryland
    Re: Last year for the 5.7L
    a 5300 mis a 5.3 which is actually about 325, or 323 or something, not quit a 327.
    The 5700 is a 5.7 and it is a 347. I know becuase i have been following corvettes all my life and when the new one came out in '97 i was all over it. it had a new design, Called the LS1, it is 347 ci, and that is what the basis for all new GM engines is including the new line of Chevy truck motors. Oh an its not an iron block anymore either fellas, its alluminum.
    Ike
    Jeep, what every boy dreams of... K5 what every man owns!!!
  11. Captkaos
    198
    Birmingham, AL
    Didn\'t I say that?
    As posted before,
    the 5300 = 325.08 cubes
    the 5700 = 346.14 cubes (LS1)
    New version GM motors are called GEN III. Only the F & Y body cars use the aluminum blocks. Truck motors use cast iron with aluminum heads.
    If you REALLY wanna get specific, the old 5.7L "350" was only 349.84 cubes
    Chris Lucas
  12. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Re: Didn\'t I say that?
    I wouldn't be too upset about the 5300 being the largest engine available in the 1/2 ton trucks. They are rated at around 270-280 h.p. (versus 255 or so in the Vortec 350's). My dad just got a 2000 Silverado and, in my opinion, runs much better than the 350's.
  13. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
  14. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    In '02, GM will allow the 6000 as an option in 1/2 tons. (That's 300hp!)
    '85 JIMMY
    '90 paint/grill/trim 5"susp 33/12.5/16.5
    Fresh 350 B&M '87 TH700
  15. Emmettology 101
    May 9, 2000
    8,126
    FL
    In the old body style 3/4 and 1 tons, you can get the 454 still and I think maybe the 350. But they are supposed to discontinue these truck in the near future.
    Mike
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
  16. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    For future reference in calculating cc to ci and vice-versa
    1 cc = 0.06102374 ci
    1 ci = 16.38706 cc
  17. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    The local GM dealer has several "older" style 3/4 ton trucks with 350's in them. These are just carry overs until the new heavy duty 3/4 and 1 ton trucks come out.
    About the Silverado trucks, I thought that was the overall name of the truck lineup in general....not just a specific trim level like it used to be. I'm pretty sure the new 2wd trucks on the lot had Silverado on them just like the 4x4's....but I obviously didn't pay too much attention to the 2wd's. I'm also pretty sure you can get the 5300 in the 2wd 1/2 tons.
  18. Captkaos
    198
    Birmingham, AL
    Silverado is..
    Silverado is the new name for the truck lineup, it isn't a trim level. The trim levels are Base, LS....
    Chris Lucas
  19. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    Actually the 8.2 is the old 502 design from cadilac for the presidential line of caddy's big and fast and somehow it gets better gas milage than a 454?with the exact same fuel injection.
  20. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Hrm? I am pretty sure that the new 502 that they are putting in the Chevy 1 tons is actually a Gen iii block. Same as the 327 (LS1). It is just bigger and badder than the 327. Oh, and guess what else. Chevy's new diesel is supposed to be bad ass. The "dura max" diesel is made by Isuzu, and it is supposed to wipe the Cummings and Powerstroke all over the board. Not to mention the fact that the 1ton engine options are the diesel and the 502 and better yet they come backed with a 5 speed automatic or a 6 speed manuel. Imagine throwing that drive line in a Blazer! If I have the money I will but the first one that is wrecked. HEHEHEHE.
    Sparky
    78 K-5
