Vortec engine questions...
Discussion in 'The Garage' started by sled_dog, Mar 12, 2006.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    anyone know how the reluctor ring and crank position sensor on a vortec motor mount? I haven't spent much time looking but it looks like the Crank position mounts to the Vortec's timing cover. So does the reluctor ring just slip onto the crank between the lower timing gear or something? I have a 383 I've been building over the past year or two and its about ready to go together and go in my S10. But I'm kind of thinking I should pull the stock Vortec 350 out of my 97 C2500 and drop in the 383 for a bit more power in my pickup.
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    what about emissons?
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the reluctor ring does in fact slip on in front of the timing chain, and has a groove at the keyway. the crank sensor is held in by 1 6mm(?) bolt. i have pics if you need them.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    as long as it will pass a sniffer test, nobody will know the difference between a 383 and a stock 350.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    pictures would be nice if you could.
    actually I don't know if its just around here but I don't think there is a sniffer test for OBDII vehicles here. Hook it up to the datalink and test to see it has passed all the onboard monitors and you are good to go. So with a PCM that eliminates those things, shouldn't be an issue to pass emissions. That or the fact that I have my inspection license and hopefully soon my emissions license...
  6. 79k20350
    Nov 22, 2004
    7,757
    Ct
    ah ways around the system, you bastard!:D
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    here they are...
    nothing really special to it. and the cover will interchange with earlier covers.
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    thanks!
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    yeah I used a can of that... Guaranteed to Pass stuff.. worked like a charm :bow:
    after I failed the first time.. ya gotta read the instructions though.. and also make your motor run lean and turn the timing down (or up I forget)... so it almost stumbles.... less power but burns more efficiently and emmissions are less...
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    eh screw it, I'm going to stick with the 350. I discovered today my truck does have to take a 2 speed idle sniffer test. I'm just going to do little stuff to the engine I have.
