vortec engine swap
Discussion in 'The Garage' started by tunedportk5, Apr 26, 2005.
  1. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    do the 96-00 vortec engines have the same bolt patterns for engine mounts and transmission.
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    my 96 looks the same as motor mounts on block. and bell yes its the same. this is for the first full vortec motors not the silverado body style.
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the 96-99 vortex are the same Gen one block as any 350 in 00 they went to the gen 3 blocks which still have the same bellhousing pattern but the motor mounts were moved. Advanced adapters sells a motor mount adaptor so you can use gen three motors in a older aplication
  4. dyeager535
    26,975
    I never got into the gen1 gen 2, etc. names, but basically, a Vortec 350 is just like any other 350. (one piece rear main, rollers, etc. different, but externally and internally same casting for the most part)
    Once they changed to the 5.3 and what not, thats when things like mounts would have changed.
