vortec head/ accesory compatibility
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dunc03, Jun 23, 2002.
  1. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    I'm looking to swap my 86 305 for a vortec 350. Will the accesory brackets bolt up directly to these heads, or will I have to drill holes in the brackets to fit hte holes tapped in the heads? Is there any body that has swapped in the vortec heads onto an older block say 87 or older and still used all the original accesories and brackets? Anything you can give on the subject is much appreciated.
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    The accesories will go off without a hitch. The throttle bracket will need some modifying, along with the solid metal brake vacuum line.
  3. dyeager535
    26,980
    Older block retrofit..don't forget you'll need a new intake. Don't even bother trying to convert the heads for an old style intake, just get one made for them. (about $180...ok, lied, just found return receipt: $153 locally for a spreadbore Edelbrock performer)
    If you have visual emissions inspection, EGR will be another issue, but that can be worked around too of course.
