Vortec heads / exhaust manifolds
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Apr 18, 2000.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    I just put some Vortec heads on my 88'K5. I was going to use some Flowtech headers untill I realized that they wouldn't fit my aftermarket exhaust system. So I decided to use my stock exhaust manifolds for the time being. Nope, won't fit. 4 out of 6 bolts fit but the last end port/runner bolt holes are about 1/2 inch off. I asked around and I guess the Vortec's are different. I can't be the only one here with Vortec heads so what are other people doing? Thanks for the help.
    Displacement, cubes, and did you say you drive a riceburner???
  2. 88Jimmy
    88Jimmy 1/2 ton status
    100
    Las vegas, NV
    Nope mine fit fine no problems at all
    Edelbrock headers
    350 Vortec TPI D60 14Bolt 4"lift 35 BFG A/T
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The exhaust manifold bolt pattern is the same on all small block Chevy heads, including the Vortecs. The log type manifolds that you have are notorious for warping, causing the problem that you now have. Do you still have your old heads? Bet you cant bolt the manifold back on them either. You can enlarge the holes in the manifolds a little to try and make them fit. I had a hell of a time gettin mine back on my '88 pickup when I rebuilt the motor.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  4. 79Cheyenne
    79Cheyenne 1/2 ton status
    Feb 19, 2000
    116
    Atlanta,GA
    Pep boys sells a spreader just for this, it fits between ports and you turn the screw to spread them, other folks I have talked to have used them with good results.
    <font color=orange>1979 BLAZER Cheyenne[​IMG]
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Yep. The manifolds fit on my Vortec heads just fine.
    '73 K5
    Chevy good...Ford bad
