vortec heads owned now.... game plan on
Discussion in 'The Garage' started by RootBreaker, Oct 16, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    aight.. got vortec heads on my garage floor now.... were on a guys truck and he blew the bottom end.....
    guy had them machined, cleaned and checked..... and they only had 100 miles on them when he took them off!!!!!
    so here is the game plan...
    Gaskets
    --Head $030
    --Intake $015
    --oil Pan $026
    --timing chain $020
    --rear main $020
    _________________________________________
    Total $111
    autozone complete kit $088
    engine parts
    --Cam comp cams xtreme $250
    --timing chain $025
    --rings $000 have em
    --bearings $000 have em
    Total $275
    Vortec Heads $200 Bought
    Vortec Intake $110 Bought
    Gaskets $088
    Cam & timing chain $275
    Total $673
    Cash $200
    Money Orders $090
    Paypal $211
    Paypal - used for house $070
    Total $102 needed still
    Trailer $200 when the guy buys it :doah:
    Total $080 in my pocket for misc stuff
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    but will those heads handle the cam lift?
    sounds like a sweet engine.
    ryan
  3. RootBreaker
    Nov 29, 2001
    5,118
    173
    summit and comp cams said yes.. .good to .480 :bow:
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    roller or flat tappet cam?
    the extreme 4x4 grind?
    ryan
  5. RootBreaker
    Nov 29, 2001
    5,118
    173
    hydraulic roller...
    here she is...
    http://www.compcams.com/Technical/Search/CamDetails.asp?
    PartNumber=08-411-8
    Part Number 08-411-8
    Engine -9999 Chevrolet
    305ci-350ci
    8cyl.
    Grind Number CS X4 260HR-11
    Description
    Intake Exhaust
    Valve Adjustment 0 0
    Gross Valve Lift 0.474 0.474
    Duration At 0.006 Tappet Lift 260 264
    Valve Timing At 0.006
    Open Close
    Intake 23 57
    Exhaust 67 17
    These Specs Are For The Cam Installed At 107 Intake CL
    Intake Exhaust
    Duration At 0.05 210 214
    Lobe Lift 0.316 0.316
    Lobe Separation 111
  6. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I'd double check myself.
    Built a crate L31 for a friend and the valve seals hit the retainers around .460" of lift on some valves. Also, maybe wrong, but the heads need to be drilled for internal coolant bypass. When I set a old style head gasket on the new vortec heads there is a coolant bypass from the waterpump passage that is not drilled on the vortec heads. I drilled them out so I didn't have to run an external bypass from the waterpump to the intake.
    We ran the GM "hot cam" kit in that motor. I has a .525/.525 roller cam with about 218/220 @.050 duration. Had to open up the spring pockets and machine down the stems for clearance, that was only $50 at the machine shop.
  7. RootBreaker
    Nov 29, 2001
    5,118
    173
    thanks for the bits of information... well seems im scrapping this entire idea....
    getting a 1987 1 ton 4x4 complete with bbc 454... gonna drop the 454 and all wiring into my truck.. dont want tbi.. but hell might as well.. dont have to touch the carb or anything..... mild 454 will do me fine.... :wink1:
    anyone need vortec heads? gonna list them in the f/s section.... $200 takes them.. i got them from a guy that said they have less than 100 miles....
