Vortec heads & roller rockers ?
Discussion in 'The Garage' started by phreddei166, Mar 26, 2008.
  1. phreddei166
    phreddei166 1/2 ton status
    Jun 21, 2007
    364
    Mass-hole !
    I have a SBC using vortec heads and Comp Cams Pro Magnum full roller rockers with poly locks. The problem is valve cover clearance. The stock valve covers were too short so I bought tall aluminum centerbolt valve covers off an E-Bay vendor. No name brand. The covers have ribs in the 4 places that the bolts go thru. The ribs should fit between the rockers, but they hit. Should i grind the ribs to clear? Or can someone tell me a name of valve covers that will clear? Yes the rockers are self-aligning type. I,d like to hear what ( 4x4high ) has to say. See pics.
  2. dyeager535
    26,218
    38
    I've got the exact setup you have. Stock valve covers fit.
    Post up pics of the stock valve covers and I'll show you where you need to grind. Or, if it makes sense, when you look at the underside of your stock valve covers, you'll see they have ribs as well. At the bottom of the ribs the metal is bent over. That hits the trunnion on the rocker. Grind enough off of each bent over lip, and they fit no problem. Also helps you guide the valve cover on. :)
  3. 4X4HIGH
    Dec 14, 2001
    21,954
    6
    Pleasanton, CA.
  4. pauly383
    Jul 22, 2001
    16,218
    Mesa , Arizona USA
    I have seen adapter plates to put old perimeter bolt tall valve covers on , don't know if the adapters clear wide body rockers though .
  5. 4X4HIGH
    Dec 14, 2001
    21,954
    6
    Pleasanton, CA.
    Those won't work. In my case i have AFR heads and i have both bolt patterns but wanted to stay with using the much better centerbolt covers.
  6. pauly383
    Jul 22, 2001
    16,218
    Mesa , Arizona USA
    True , the centerbolts seal better , but don't aftermarket heads have raised valve cover mounting rails for less leaking ?
  7. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,957
    center of CT..ish
    my friend had the same problem, he ended up getting the center bolt covers that are black with the bowtie and chevrolet in red on them...i think they're in jegs
  8. phreddei166
    Jun 21, 2007
    364
    Mass-hole !
    ( dyeager 535 ) Here's a pic of the stock height covers I used with stamped rockers. The covers are also e-bay vendor issue ( no name ) Can't imagine that these would work without ripping out all ribs. I,m going to try grinding clearance in my tall alumimum covers . If still no luck I'll grab what ( 4x4high ) recommended. Anyone else have a valve cover that worked ?
  9. dyeager535
    26,218
    38
    What was the issue?
    I think I've even got pictures somewhere...I've got stock vortecs (original studs, comp pro magnums) and had no issue. Not sure why the OP would.
  10. dyeager535
    26,218
    38
    Can only view a small image here, but looks to me like those are stock-style. Why wouldn't they work with the ribs in place, if narrowed at the bottom? The stock rockers had to fit between them, the ribs are essentially dead center between the opposing studs, so as long as there is clearance between the rockers, the rib will fit if it's narrow enough.
    Don't forget, the trunnion is the widest part of roller rockers, but it doesn't move, so there is no issue with clearance.
    Here are what pics I've got:
    http://dyeager535.topcities.com/vortec.html
    Looking at another pair of stock valve covers I've got, it appears that maybe the above pictured aftermarket factory style replacements have larger "windows" in the support pieces, but even the factory ones would have that issue. It's just that lower lip that is clearly shown, and maybe the PCV baffle, although the stock PCV baffle clears the comp pro magnums ok.
