Vortec heads
Discussion in 'The Garage' started by SUPERSUB87, Mar 11, 2007.
  1. SUPERSUB87
    SUPERSUB87 1/2 ton status
    Oct 16, 2006
    463
    TEXAS
    ok so im planning on buying some vortec heads this summer.:D
    few questionss
    1. are the aluminum heads worth the extra dough (cons)
    2. would i need to buy an intake manifold for the vortec specific heads?
    3. do they really get as much of a horsepower increase as they say they do?
    thanks a million.
  2. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    1. the aluminum heads are only worth the money if you are going to be running high compressions (in excess of 9.5 to 1)
    2. yes you will need a vortec specific intake manifold, the vortec ports are much taller than older style heads, and the vortec port will actually extend over the top of the old style manifold by about an 1/8 of an inch. no there is no way to modify them to work together.
    3. i would also suggest getting a pair of iron heads off a junkyard truck, save a boatload of money and have a set of fantastic heads. clean em up and throw em on. you want the heads off light duty trucks with casting numbers ending in 062, avoid the ones that end in 908
    4. as for the power increase, yes there is a big difference depending on engine combinations. for a completely factory engine, youre probly looking at 30-50hp more. especially in the lower rpm ranges. the strength of the vortec heads are in the low lift, from 0-.2 inches of lift. which does a great job filling the cylenders at low engine speeds. so there will be a very big difference in off the line acceleration. top end might not change much due to cam specs, carb size, exhaust yadda yadda
  3. dyeager535
    26,975
    Aluminum is really only good as a weight saver. You HAVE to run higher compression with AL heads to make the same power as iron. AL sheds heat better, and heat is power. To up the heat, you up the compression. :)
    A good set of aftermarket heads (AFR, world, etc) properly chosen for your application will probably make more sense than the Vortecs, although the cost will likely be higher.
    There are all sorts of shortcomings and one-off issues with the Vortec heads, they've been spelled out before on this board. I'm too tired to write all of them up again, but a search should yield some answers.
    If you decide to go with Vortecs, check with RHS and EQ(unsure of both of their websites) as they both offer replacement Vortecs that are probably better than stock ones, at little to no extra cost.
  4. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    ok thanks a lot.
  5. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    the Cast Iron Large Port Vortec SBC Heads accept old style intake as well as vortec intake, plus they will accept centerbolt or perimeter valvecovers, you will have to run self aligning rockers.....these are supposedly better than the L31 vortecs that they say will out flow phase 2 bowtie heads straight out the box, so these must really be some good heads, plus all your stuff still fits
    http://www.jegs.com/webapp/wcs/stores/servlet/productitem_10001_10002_757456_-1_320634
  6. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    Now them look nice, it says it accepts both intake patterns, but I wonder do the ports line up?
  7. K5dreamer
    Mar 14, 2005
    3,084
    Alexandria, Va
    if they advertize them as working, well i guess they do, but the ports are so different im really not sure how they do. :confused:
  8. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    If you want a good set of heads cheep, try and find the older style vortec heads. Granted they don't flow much up in the higher RPM range but they sure do produce a butt load of lorque down low. Thats what we are looking for in our truck besides right? That is unless you wanna drag race. Aluminum are great, edlebroc makes their version of the vortec's and they produce good number. Get the ones with the smaller valves though, you'll end up with more torque than the big chambered heads. Benifit is you get to run higher compression and done right you may pick up some MPG because of the higher compression. (engine will be more efficient)
    Have fun!
    ~Brian
  9. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
  10. Brians89K5
    Jan 4, 2006
    535
    Rialto Ca.
  11. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    i like trick flows for aftermarket, plus they look cool like a bbc with the canted valve
    or actually while we are talking over the rainbow i want a set of sb2.2 heads and intake!
  12. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    sorry for the hijack, curious, 454's,,,,were there ever Vortec ones made?
    some guy on Craigslist is selling a F.I. system, with (he's claiming) a Vortec intake manifold..
    curious...
  13. 76zimmer
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    Yep 96 and up production trucks
  14. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I'm just finishing up a MPFI 383 w/ RHS Vortec heads for my '90 K5. I'm really ready to see what this thing will do. Desktop Dyno shows peak TQ @ 440 lb/ft. at 2500 RPM. This is right where my truck cruises when towing my camper. Peak HP show about 380 at 4500 RPM.
    I know they made Vortec BBC's but it seems that the Vortecs didn't have as good of a reputation in the BBC's. It does seem like maybe the stock BBC heads have been better than SBC in the past, so maybe the increase was not all that significant. :dunno:
  15. 76zimmer
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    I think HP went from 235 to 290 with the 454 and vortec setup.
    350 was 210-255
  16. 4xcrazy
    Oct 31, 2003
    9,471
    5
    interesting, was just pondering the idea, as mentioned in MY previous posts about the 454 deal, it's going in a tow rig, so more power/torque would definately be nice,,,,along with alittle better fuel mileage while not towing anything but my lardass around :D :p:
  17. 76zimmer
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    My 96 454 had 420 torque @ I think 3600
