Vortec heads
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Doug, Nov 2, 2001.
  1. Doug
    Doug Registered Member
    Sep 1, 2001
    56
    Northern Colorado
    This in regards to my '93 454. It will be time for a rebuild soon, and have been considering vortec heads for it. Will the intake and exhaust manifolds bolt up with no problems? Any extra considerations?
    '85 K5, 350, 700r4, np208, 10 bolts, as of 10/2001; wish list is extensive.
  2. Doug
    Sep 1, 2001
    56
    Northern Colorado
    No one???
  3. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    sorry i don't know anything about trucks that new.
    SWAMPERS RULE!!
    scott,
    1989 GMC suburban 3/4t 4" lift finally rollin on 36" swampers, tbi350, th350, np241
  4. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You'll need some machining to get your intake to fit, exhaust will be fine.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  5. gator1959
    gator1959 Registered Member
    Nov 4, 2001
    36
    you will have a hard time machining sbc heads onto a bbc? if you want performance go w/edelbrock performer rect. ports,for up to 500 h.p. go with iron oval ports.
    '79 K-5,D-44HD(8-bolt),14 bolt(FF),4.09 ratio,427 rat,auto,38" rubber,currently taking body off frame
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I have no knowledge of an intake for BBC style vortech heads. Machining to fit is a bad idea. Circle track guys did this so they could run the vortechs and most of them leaked like a siv. Not worth the problems IMO. Lots of good aftermarket BBC heads that can be had for a lot less $$$ then the cost of machining and buying the heads in the first place.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
