vortec heads
Discussion in 'The Garage' started by RedneckK5, Aug 3, 2003.
  1. RedneckK5
    RedneckK5 Registered Member
    Aug 15, 2002
    42
    texas
    does anybody know if i can use vortec heads on a 78 350 block with throttle body fuel injection of a 91 350. i know the heads will fit the block but will the 91 intake fit the 96-99 vortec heads?
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Nope, gota get a different intake. GMPP sells tham and i ThINK edelbrock does too.
  3. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    that is one option here is a few more, you can have you intake machined, what they will do is put wedges on the mount holes or you could have the heads machined to fit the mount holes in you intake here they will drill all twelve holes into the vortec heads. make sure you check the compression because I was thinking of this also and was told that vortec heads are 53cc and older heads are 64cc or 76cc this may put your compression up higher then you would like for running pump gas /forums/images/graemlins/thinking.gif /forums/images/graemlins/burb.gif
  4. ben427
    Mar 10, 2002
    1,123
    350 Vortecs are 64cc and they are not cast to have the 12 bolt intake pattern so material there gets pretty thin and that is not recommended.
  5. dyeager535
    26,979
    The intake ports are raised on the vortecs, redrilling them for an earier intake is a waste of time.
    Buy aftermarket Vortec knock offs (setup for the older intakes, ports should match) or go with AFR's, etc., that will accept the older intake.
    Or buy Vortecs and go with the GMPP intake, and all the other Vortec issues which have been covered on here a LOT. No flame, just saying you've got a lot of reading to do if you want to learn all sorts of stuff. Carbed low performance Vortec headed engine is easy, you start spending more if you want more out of the engine.
