vortec manifolds in K5 frame?
Discussion in 'The Garage' started by CCRider, Jan 2, 2003.
  1. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    Am wondering if vortec manifolds fit in a k5 frame without any trouble here's some pics of the vortecs [​IMG] [​IMG] and the standard blazer manifolds I've got now look like this [​IMG] anyone running the vortecs? .............CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Those appear to look like they will fit. I notice the driverside manifold exits at a lower angle, but I dont think that interfers with anything. Anyways, why dont you just get headers? /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif
  3. CCRider
    Jul 8, 2001
    314
    I can get the vortec manifolds on e-bay for 30$ already has the egr tube for my vortec head conversion , won't have to deal with gaskets leaking , can keep the tubes higher in the chassis(reason for looking at the left side especially) and gives me more options on the 2into 1 pipe ...............Thanks, need real world facts if they'll fit ' that left one is kind of wide from the block!!! .................CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  4. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Well if your going through the trouble of converting to Vortec you might as well go ape sh*t and get the vortec mainfolds to compliment your heads and intake. /forums/images/graemlins/thumb.gif
  5. CCRider
    Jul 8, 2001
    314
    Just want to make sure that's a viable option with clearance before I do this , If they don't fit , I can take a different route (shorty headers, etc.) thanks...............CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  6. CCRider
    Jul 8, 2001
    314
    Has anyone done a swap of a newer engine and kept the manifolds? Somebody?....... /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  7. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I think this was kicked around some time ago and it was determined that there is no difference. When I did my 383 w/Vortec heads swap, I used Edlebrock headers and there was no special part # for Vortec headers.
  8. bigbluek20
    bigbluek20 1/2 ton status
    Dec 18, 2001
    119
    Loveland, Colorado
    Can't comment on the 350 but I can tell you about my vortec 454 swap into an 82 /forums/images/graemlins/truck.gif
    Basically, it fit. However, the EGR tube is a little "squished" shall we say against the firewall. Particularly, against the lip at the lower part of the firewall. I also had to remove a heat shield from the left side manifold (It might have fit once in, but it wasn't fitting while trying to negotiate the beast into the truck with the 4l80 still attached /forums/images/graemlins/smirk.gif ).
    Good luck.
  9. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    Yup, I'm not done yet but there is a vortec motor with manifolds in my 87. Still need to take it to the exhaust shop and have the rest of it built, but the manifolds fit fine.
    Mike
  10. JAXSTER
    JAXSTER 1/2 ton status
    Mar 15, 2000
    181
    DFW, TEXAS
    Just put some in my burb, K5 same frame they fit.
  11. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I run shorty headers for a 88-98 fullsize truck on my 71, the should also work on your 91
