Vortec Performer vs. Performer RPM
Discussion in 'The Garage' started by BigJohnson, Mar 5, 2003.
  1. BigJohnson
    BigJohnson 1/2 ton status
    Jan 22, 2001
    207
    AL
    How much difference in low-end power is there between these two intakes? I have the RPM intake now and I am thinking of changing over to a Performer intake to use with my new q-jet. Would this swap be worth the effort and money?
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    If I follow you, you are changing from a normal bolt pattern Performer to a Vortec bolt pattern? Are you changing to Vortec heads? If so, there is a big power difference. Heard number of just the heads being better than double humps, and thats with the 1.94 valves to dhh 2.02!! Couldn't tell you about modifying the manifold to prevortec heads.
    Hope this helps.
  3. BigJohnson
    Jan 22, 2001
    207
    AL
    My mistake, my question wasn't very clear. I have a Vortec 350 now with a Vortec Performer RPM intake and I am wondering if swapping to a Vortec Performer intake would increase my low rpm power and throttle response.
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Dyno tests that I have seen comparing the two show very little if any loss of low end torque with the RPM vs. the Performer. I would just keep the RPM unless you have some other reason to change. What cam you use is going to have a LOT more effect on your torque curve than the difference between those two manifolds.
  5. Nikk
    Nikk Registered Member
    Dec 16, 2002
    34
    Lacrosse, WI
    I agree with the above post by Tim
