Vortec spring lift? and what is the compression of a Vortec 350?
Discussion in 'The Garage' started by sled_dog, Apr 23, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I seem to remember vortec springs can only take .450 lift am I correct? I am going to change the intake and head gaskets on my 97 soon and I was thinking while I am that far why not put in a nice torquey cam and do some head work to it. The 2 cams I'm looking at are the comp cams XR252HR and the XR258HR. see specs here
    Both have like .470+ lift. Also anyone know what compression my 97 350 has?
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Stock Vortec spring are considered weak to begin with. Any performance cam should have better springs installed with it.
    I thought it was the slot in the slot rocker that limited the lift, rather than the springs themselves /forums/images/graemlins/thinking.gif
  3. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    i didnt look at the specific model cams your looking at, but you are looking at roller cams right? the stock vortec cam is hydraulic roller. rplacing it with a flat tappet is a downgrade.
    get Z28 springs and LT4 retainers, and you'll be good to go. /forums/images/graemlins/waytogo.gif
    i think the compression is high 9's, maybe 10.0ish? i dunno.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah cam is roller, I think I'm not gonna bother with the came now, cams run like $350(I knew Hydraulic roller wouldn't be cheap) so just some head work, maybe do the springs and retainers to save that work in the future.
  5. dyeager535
    26,977
    .450" lift on my vortec heads, is about max. I ran out of valve spring retainer to valve guide clearance.
    Putting a .452" lift roller cam in my older block, I had to cut quite a bit of material off of the Vortec's around the pushrods. The holes are pretty small, and the pushrods contacted the head at almost every cylinder.
    Vortec cam lift is something like .420", so an aftermarket cam is almost certainly going to require more seat pressure, and with Vortecs, you start getting into special springs at that point, with very little variety, OR have your heads machined.
